R3345
- Jun 11, 2014
- 10
I'm designing a eccentrically loaded lifting linkage and I'm wondering the best way to calculate stress as there is a combination of tension and bending.
The linkage is made up of 1m long 25mm diameter round bar with a rod end on one end. The other end has a plate welded along the side of the rod. The plate has a hole for loading, so the loading is say 50mm from the axis of the rod.
I've played around with working out the lateral component of the force and then applying beam bending calculations but I need to know how to consider tensile and bending stress combined.
Apologies for the crude doodle
