Part Name as Atrribute 2
Legs11
AU
I am using native NX8.5 and want to know is there a way to call the name of a part file into an attribute in that same part? So if I have an attribute called "name" for instance and the part is called "123.prt" I want the attribute "name" to equal "123". The idea is that if I do a Save As on the part and call it something different the attribute "name" will automatically pickup the name of the new part file.
The reason I am wanting this is I have a range of attributes called out into a spreadsheet and currently I am manually editing this value to the name of the part. I thought there might be a way of calling this out automatically. I know there is a bunch of things I can do with parts lists and automatically calling out info but I really need this as an attribute in the part.
Jackie.
Attached is a video to demonstrate what Joe is referring to.
You will be forced to update to get the expression to change.
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
This is the string I ended using in the expression:
ug_setPartAttrValue("NAME",subString(ug_askCurrentWorkPart(),1,8))
This returns an Attribute called "Name" with the first 8 characters of the part name.
As my file names are all 8 characters long this works well. After I do a Save As I have to run the Update for External Change on the assembly to have it update the Attribute but that saves me having to type it manually.
Thanks Joe for the telling me about this function. Interestingly if you do a search or even a "List All" in the Expression function menu this function is not listed.
Thanks for your help,
Jackie.
