Issue with solve
DarkDaredevil
Hi all,
I am running a flow solve over my car body model and encountered an error during the solve.
I was wondering if I could get some assistance on how to fix this error.
Thanks.
Hi DarkDaredevil,
You may try to do the above recommendation by the solver. You can find these parameter by setting below:
1. Right-click Solution, select Edit Solvers Parameters...
2. In the dialog box, go to 3D Flow Solver Tab..
3. Reduce the suggested value... (how much to reduce? probably you can check another forum cfd-online.com)
If problem is not solved, then you might want to check your fluid mesh for bad quality elements. From my experience with CFD, most of the time, the problem is originated from the mesh itself.
Good luck,
Tuw
