For a concrete pad on grade (e.g., to support a trash dumpster), should reinforcement be at the top or bottom of the slab? My opinion is that reinforcement is at the top to control cracking. Reinforcement is not necessary at the bottom since the bottom of the pad really should not be under any tension (it is supported by subgrade).
