brass brazing
shermick
Marine/Ocean
PL
I want to braze or solder tubes (made from marine grage brass) to tubesheets (marine brass as well)in boat heat exchanger. The two above technologies seem easy, but I am seeking the most corrosion resistant way-out. Is silver solder (45 % Ag) resistant enough? Maybe something different should be considered? Any advice will be very helpful.
Harris just marketed a product they are calling BLOCKADE. It might be what you are looking for or, you can check their website for additional info.
