higher
- May 9, 2005
- 1
Hello. Can anyone out there please correct my 45,90,180,270 and -45,-90,-180,-270 conversion routines and complete the 2 missing routines. I will be in a greatful appreciation.Here is my code:
org 0000h
jmp MAIN
org 0100h
MAIN: CALL ROLLSTOP
mov p3,#11111111b
START: jb p3.0,FORWARD ;PIN 3.0 IS ON - forward
jnb p3.0,REVERSE ;PIN 3.0 IS OFF - reverse
jmp start
FORWARD: MOV A,#98 ;WAIT 1sec TO START RUNNING
CALL WAITS
CALL INITFORWARD ;SET MOTOR IN FORWARD MOTION
CALL WAITS
CALL FORWARDSHAFT
CALL WAITS
CALL ROLLSTOP
jmp start ; ß---clockwise
;SET MOTOR IN REVERSE MOTION
REVERSE: MOV A,#98 ;WAIT 1sec TO START RUNNING
CALL WAITS
CALL INITREV
CALL WAITS
CALL REVERSESHAFT
CALL ROLLSTOP
jmp start ; ß---counterclockwise
WAITS: MOV R2, A ;FULL WAITS (SHORT) IS APPR.2 sec
WAIT2: DJNZ R0,WAIT2
MOV R0, #00000011B
DJNZ R1, WAIT2
RET
PAUSE: MOV A, #49 ;PAUSE 1/2sec AFTER MOVING
CALL WAITS
RET
;SET FORWARD MOTION
INITFORWARD: ;The unipolar stepper motor begins in motion ( Phase 1)
MOV P1,#00000001B ;1
CALL PAUSE
MOV P1,#00000010B ;2
CALL PAUSE
MOV P1,#00000100B ;4
CALL PAUSE
MOV P1,#00001000B ;8
CALL PAUSE
RET
;SET REVERSE MOTION
INITREV: ;The unip. step. motor begins its backw. motion ( Phase 2)
CALL PAUSE
CALL PAUSE
CALL PAUSE
CALL PAUSE
RET
FORWARDSHAFT: ;Turn shaft in certain positions during FORWARD movement
MOV P1,#00010001B ;Turn it 45 degrees.
CALL WAITS
MOV P1,#10000010B ;Turn it 90 degrees.
CALL WAITS
MOV P1,#00001001B ;Turn it 180 degrees.
CALL WAITS
MOV P1,#01000010B ;Turn it 270 degrees.
CALL WAITS
LJMP START
RET
REVERSESHAFT: ;Turn shaft in certain positions during REVERSE movement
MOV P1,#01000010B ;Turn it -270 degrees
CALL WAITS
MOV P1,#00001001B ;Turn it -180 degrees
CALL WAITS
MOV P1,#10000010B ;Turn it -90 degrees
CALL WAITS
MOV P1,#00010001B ;Turn it -45 degrees
CALL WAITS
LJMP START
RET
;FASTROUTINE: ;Maximum speed to the UNIPOLAR STEPPER
;SLOWROUTINE: ;Minimum speed to the UNIPOLAR STEPPER
ROLLSTOP: MOV P1,#00000000B ;TURN OFF MOTOR
RET
END
org 0000h
jmp MAIN
org 0100h
MAIN: CALL ROLLSTOP
mov p3,#11111111b
jmp start
CALL WAITS
CALL WAITS
CALL FORWARDSHAFT
CALL WAITS
CALL ROLLSTOP
CALL WAITS
CALL INITREV
CALL WAITS
CALL REVERSESHAFT
CALL ROLLSTOP
MOV R0, #00000011B
DJNZ R1, WAIT2
RET
CALL WAITS
RET
;SET FORWARD MOTION
CALL PAUSE
CALL PAUSE
CALL PAUSE
CALL PAUSE
RET
;SET REVERSE MOTION
CALL PAUSE
CALL PAUSE
CALL PAUSE
CALL PAUSE
RET
CALL WAITS
CALL WAITS
CALL WAITS
CALL WAITS
LJMP START
RET
CALL WAITS
CALL WAITS
CALL WAITS
CALL WAITS
LJMP START
RET
RET
END
