Tungsten electrode preparation
welder123
Nuclear
May 20, 2002
9
For the GTAW welding process of an open butt weld on 2 1/4% Cr piping would it be better to have your tungsten electrode sharpened to a sharp point or sharpened with the sharp point flattened at the tip?
I have always preferred the sharp tip,esp.for x-ray work.
"Chem-Sharp"works really well. If you grind be careful of your grinding direction. With a fine sharp tip you also must be more careful with the amps to avoid melt off and tungsten inclusions.
In making a butt weld on 0.040 Alu tubing is pulse welding a good technique too use?
Elecrtodes used for DCEN welding are to be ground to a sharp point. The general rule is the taper should be 2 1/2 times the diameter of the electrode.
Although a sharp point on the tip promotes easy arc starting, it is not recommended because it will melt away and form a ball on the end.
Sharpen it as you always have, then slightly blunt the tip. The flat tip angle will maintain its shape within the current range recommended.
It would depend on the thickness of the sheet / plate you are welding . For higher currents you should flatten the tip slightly to prevent melt off .
Rule of thumb: Flat diameter = amperage/4000 (for example: 80A/4000=0.020")
Different angles produce different arc shapes and offer different weld penetration capabilities. In general, blunter electrodes that have a larger included angle:
· Last longer
· Have better weld penetration
· Have a narrower arc shape
· Can handle more amperage without eroding.
Sharper electrodes with a smaller included angle:
· Offer less arc wander
· Have a wider arc
· Have a more consistent arc
