shesanEIT
- Dec 7, 2015
- 17
Definitions from ACI 318-14:
Anchor – Steel element either cast into concrete or post-installed into hardened concrete used to transmit loads
Cast in Anchor - is only a headed bolt, headed stud, or hooked bolt.
Post-Installed Anchor – expansion anchors, undercut anchors, adhesive anchors (including threaded rods)
Can I use a threaded rod with a nut for a cast-in-place application, or is the code telling me I can't??
I also found this from the "Handbook of Structural Engineering - Second Edition"...but all the references are ACI 318-02. I thought I could use threaded rods with nuts cast-in no problem.
