Tunalover
- Mar 28, 2002
- 1,179
Folks-
Can anyone recommend a process for bonding open-cell silicon sheet material to sheet aluminum? Likewise for solid silicone sheet material.
The environment is pretty nasty: saltfog, condensing humidity, rain, vibration, shock, dust, and temperatures from -40C to 90C.
The solid silicone sheet is per US FED STD ZZ-R-765/GEN. The closed-cell foam material is medium firmness, Saint Gobains #R-10470-M.
The sheet aluminum will be chemically treated per MIL-C-5541, Class 1A (or 3). If helpful, the aluminum can be orbitally sanded to provide a rougher surface.
Ideally, we want a bond so good that the silicone will fail before the bond fails. Is such a thing possible?
