Suitable material for the punches
n348592
1
I'm working in a perforation plant. We have some difficulties with the small dia (1.5 mm) punches. Material to be perforated is soft galvanised steel in 0.5 mm thickness.
I guess the material (HSS) and/or heat treatment (60 HRC) is not good enough for the punches.
Can you advise your experiences regarding this subject?
Thanks in advance.
Where are you purchasing your punches?
Are your punches coated?
