StructEngineer11
I have been tasked with designing concrete piers that will support existing wood columns, and I was wondering if anyone could offer any helpful tips as far as how I should approach the design from the beginning. The wood columns currently stand on top of a concrete slab, but due to water/other liquids on the slab, the columns have started to rot a good bit. Thus, the bottom 3-4 feet of the columns will be cut off, and the columns will be placed on new piers that will project from the top of the existing slab.
Any tips as far as how to design the concrete pier? How to design the connection from the column to the pier? I was told that the column will be placed on a steel base plate, sandwiched between two steel angles, with a couple of bolts going laterally through the column and two angles, and 4 anchor bolts going through the angles and base plate into the concrete pier. See attached image.
Any help would be appreciated. Thanks!
