I have a 72" blind flange and need to attach a 12" pipe at it, as in the sketch below:
My question is: can I size the thickness of that blind as per ASME Code Section VIII, UG-34? Or, since is a blind with openening, the thickness is bigger than a regular blind thickness. I didn't find in the ASME Code this specific case, can someone help me?
Thanks.
Thanks.
