BSVBD
- Jul 23, 2015
- 463
I have an existing flat rubber roof.
We will reroof over the top of existing with metal deck and CFS purlins, studs and base track with strap and cross-bracing at uniform spacing, E.W. throughout. The base track "was" intended to be anchored, with TEK5 screws, through the rubber membrane, rigid insulation and metal deck, to the top chord of OWSJ (Open Web Steel Joists).
HOWEVER, with round top chord joists, can I please have (alternate) suggestions on how to accomplish this?
(Please forgive the position of photos. They were not taken with this thread in mind)
Thank you always!
Thank you always!
