sedesigner06
I have a grade beam that is spanning between to drilled piers acting as a torsional member for a roughly 5' high retaining wall. The ideal layout with grades puts the grade beam at roughly a 20 degree angle.
I have some flexibility as I can lower the upper driller pier to reduce the angle. I would like to avoid a stepped footing scenario as I am using the grade beam as a torsional member as stated above.
My question is there a limit on the slope of the grade beam. I know low slump concrete may have to be used but wanted to reach out to others that may have some insightful information.
Thanks!
Thanks!
