Check Mate or Journal to check features by colors in NX11
PSI-CAD
Computer
Feb 13, 2009
997
I have colored features and I need a way to list all of them
Is there any way by using check mate or does anybody have this kind of journal ?
Thanks in advance
Didier Psaltopoulos
Didier --
There's not an OOTB Check-Mate Check for this. You'd need some significant customization here.
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Product Engineering Software
Siemens Product Lifecycle Management Software Inc.
(Phoenix, Arizona)
If you are using associative feature colors then you can just activate the color column in the part navigator to get that information.
Hi @DidierPSICAD,
Probably this example can help you. This NXOpen application assigns random colors to all part features, which are available for painting. It is possible to use some of methods and classes to obtain the list you needed.
Thanks Petulf,
OK, but now I need to find a way to list this information in a text file.
Hi Lockdain
OK, bu I am not an expert in java or vb
Didier Psaltopoulos
DidierPSICAD: Right click part navigator and select export to spreadsheet.
Of course if you need to do this for multiple parts in an assembly, then nxopen would probably be a better choice.
Hi Petulf,
I have found another way by using CTRL-I on features then save information window but your solution is better (more clear)
Thanks a lot
Didier Psaltopoulos
