TekEngr
- Feb 4, 2012
- 148
I am designing a one small hot rolled steel shed (Sizes 12mx21mx5m) in SAP 2000 and shed is open from all four sides. I cannot provide cable bracing and portal frame bracing in wall due to client’s restrictions so that’s why I am providing eave tie member (SHS 100x5) to control the longitudinal drifting and I am planning to provide the moment connection (end plate connection) at both ends of the beam.
However the shed is open from all four sides and there is only column and rafter surface area wind effect (2 KN wind point load at eave for each column) so my question is that does this scheme will work practically (in SAP drifting in under limitations and and all members are working) or any other suggestions??
However I know the column section its self can restrained this little force (2 KN) in week axis.
