what is the best material that is strong light weight and weather proof??
Jordan77
Industrial
Jul 18, 2017
Aluminum, carbon fiber, aerogel... without useful input data, the answers will be just as useful
Dan - Owner
URL]
Usually, you're doing good to get 2 out of 3.
You need to cough up some more details, like, application, environment. etc. Diamond fits the bill, but for a very limited set of applications.
TTFN (ta ta for now)
metal, non-metal?
how big?
does cost matter?
temperatures?
impact? color? what shape?
Too many open questions.
Hi Yeah something that is light weight, strong, durable and weather proof.
Product must be low cost and have colour to it.
Im wanting to make a box with it something like 450x350x350
Looking to hinge the top also
Any suggestions????
A box for holding feathers or elephants? Tell us more...
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
Jordan77, you do know this is an Additive Manufacturing (think 3D printing) forum, right?
Another ill-defined problem in search of a magic wand...
Mike
A 450x350x350 micron box will be tough to build if you wanted it to hold 500 metric lbs of unobtainium.
Plenty of ways to make a flex joint, if he just wants it to hinge once.
Weatherproof, so you want the box to seal, and resist sun, rain, hot, and cold?
And you want to do it additive, because????
They are called injection molded enclosures and electronics guys use by the millions.
