chbake
Chemical
- Dec 10, 2002
- 6
Last year, our plant consulted with a metallurgist on some weld defect issues associated with our continuous casting belt. The belt is a 0.060" thick piece of stainless steel, 12 meters across, and about three football fields in length. It's welded in multiple areas to join the stainless steel sections. The equipment is used to cast acrylic sheet. The consultant characterized one flaw, viewed at 10X magnification as "undercut". What is the technical definition of undercut?
