IFRs
Petroleum
- Nov 22, 2002
- 4,676
I've been tasked with designing construction guy wires for a 23' dia x 122' high steel stack being built on the ground. I started with quite a few simplifying assumptions but want to put a finer point to my pencil. I'm using ASCE 7-10 for the wind loads and ASCE 37-14 for construction factors, I'm researching coefficients of friction between the concrete weights and what they rest on ( steel plate and grade ), using standard wire rope strength and termination factors, I'm assuming the stack is rigid but may revisit this later, I'm not sure if cable preload is a major factor, etc. Comments and suggestions are welcome so I don't overlook anything major. Thanks!
