The Canadian Highway Bridge Design Code (CSA S6-14) calls for shear connectors to be installed at a maximum spacing of 800 c/c along precast concrete culvert joints with less than 0.6 m of soil cover. This aims to protect the pavement overlay from differential settlement effects in the case of a wheel load on one side of the joint.
As per CHBDC clause 7.8.14 (text attached), shear connectors are to be designed for an unfactored shear load of 60,000 N per meter of joint length. What design approach would you follow in designing these steel connectors and their post-installed bolts? Does anybody have any sources/references that contain a design example for such an element? I was able to find manuals showing typical steel shear connectors, but I was not able to find any sources on the design methodology followed. Thank you in advance.
