mysterymike
- Dec 19, 2002
- 8
Hey, if I have a water fall in my pond, on a small pump, can I get a valve which could control the rate of flow to the waterfall using a simple light dimmer type input? Does such a items exist or will I need to by a high end valve that is a 4-20ma or 0-10V control and then "create" the control signal with the dimmer etc? I have a single phase drive here too so I thought about slowing the pump down but thats just seems to complicated for a pond, and the drive is worth a few hundred bucks alone.
I am electrical, automation, but no experiance with water valves. Home project, looking for "cost effective" not some stainless steel explosion proof $2000 valve if you know what I mean. Thanks.
