mjohan
- Dec 7, 2002
- 91
What is the most common type of bolt connection for a steel beam to angle, knife plate, etc..., slip or bearing type connection?
If you analyze the connection as a bearing type connection, how, when built, can the designer be assured that the connection is indeed a bearing type connection? It seems that by tightening the nut would most likely create a slip/friction type connection.
Mark
Mark
