hey guys,
i am designing a moment end plate connection and i am considering adding backing plates for the column flange, now in the Euro-code the backing plate is added from the inside (see snapshot),
my question is this, if we added a plate at the outside of the flange, how will the behavior change in this situation, do you guys think that it will be different form the concept in Euro-code, if yes, how??
ôIf you don't build your dream someone will hire you to help build theirs.ö
Tony A. Gaskins Jr.
Tony A. Gaskins Jr.
