Marauder
- Feb 3, 2003
- 2
I am working on improving application of in-mould paint with a PU system. Current method is using manual spray gun, but it is inconsistent and operator-dependent.
The method I had in moind was to use multiple nozzles to spray around the mould and (hopefully) obtain consistent even coverage.
1. Any suggestions of a nozzle that would do that? I imagine it would have to spray an ellipse pattern per nozzle, so a group of nozzles would provide for the required shape.
2. Any better ideas? Robots are out due to cost...
3. Related to the same issue, I have much difficulty measuring the thickness of the paint on PU. I attempted an ultrasonic gauge, but the readings were inconsistent on the same spot. To complicate matters, I believe the paint reacts to the PU so there is no real distinct boundary. Any suggestions?
Thanks!
Thanks!
