KimWT
- Jul 15, 2003
- 71
Hi!
I copied two load bearing spandrels from different projects of parking structure.
Longer spandrel does not have baring plate at both ends though short one has.
Apparently, some precast design engineers do not add bearing plates for precast concrete load bearing spandrels.
Is this industry wide design trend?
Doesn't PCI Design Handbook recommend bearing plate should be added under the assumption of the potential crack line?
I have found some engineers do not use bearing plate for precast inverted beams.
I am looking forward to your comment.
Thanks!
Kim
Thanks!
Kim
