waytsh
- Jun 10, 2004
- 373
Let me bounce this off you guys to get your thoughts. I am going to have a short cantilevered masonry wainscot wall on top of a concrete foundation wall, which in turn is on a strip footing. I would like to keep the concrete foundation wall and the masonry wall both at 8" but am concerned about the slab. I would like to tie the slab into the foundation wall to eliminate the overturning on the strip footing. I have attached two details for reference. One with a 10" concrete foundation wall and one with an 8" foundation wall (preferred).
My concern with the 8" wall is having the slab corner come under the masonry wall. My concern with the 10" wall is that it is a lot of extra concrete when you consider the entire perimeter of the building. A third option, which I haven't shown, would be to cut the concrete wall down, overpour the slab, run the wall reinforcing through the slab, and lay the block on the slab. I would welcome your opinions on the best way to detail this condition.
PS - don't get too hung up on the reinforcing shown. I haven't worked that out yet.
Thanks!
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1551195476/tips/Preliminary_Foundation_Details_w6e4qg.pdf[/url]
Thanks!
