Kellymint
Aerospace
- Feb 10, 2003
- 1
I have 6000 psi 1/4" S.S Helium supply line for a test lab that was only hydrostat pressure tested to 6750 psi. The facility contractor should have been proof tested this to 1 and 1/2 times, or 9000 psi. The system is already installed in place and it is not feasible to perform another hydro. For a pneumatic proof test, in place of a hydrostat, I have seen test pressures anywhere from 10% to 25% over MEOP. I do not have a latest copy of ASME 31.1 or 31.3. Does anybody know what the test pressure should be and how long I should hold that pressure? And if only 110% is needed for a pneumatic test, do I really need to perform the proof test again?
