Joselito
- Jun 24, 2002
- 14
I have sheets of 0.080 inch aluminum - approximately 8 inches wide and 150 inches long. I want to make an L-channel from two of these sheets.
The L-channel will be standing with it's 150 inch axis normal to the ground. The corner weld will be under a light load. Approximately 4 pounds.
I'm planning on fillet welding the corner as shown below:
sheet | \
| Weld _________|__________ | |
| sheet |
I need to figure out what axial length and at what interval the welds should be, if placed in the above configuration.
Thanks very much
Jose
sheet | \
| sheet |
Thanks very much
Jose
