Flat roof snow load - exposure factor Ce
cav28
1
Can anyone provide insight on when you can consider a building as fully exposed? The terrain/parapet conditions are pretty straightforward but the mechanical equipment note is pretty vague. Typically I would just consider a building as partially exposed but I'm currently looking at an existing structure and would love to sharpen my pencil and use Ce = 0.9 when calculating flat roof snow load. It meets requirements for terrain and parapet but does have some mechanical equipment.
As per ASCE7:
Partially Exposed: All roofs except as indicated in the following text. Fully Exposed: Roofs exposed on all sides with no shelter
afforded by terrain, higher structures, or trees. Roofs that contain several large pieces of mechanical equipment, parapets that extend above the
height of the balanced snow load, or other obstructions are not in this category. Sheltered: Roofs located tight in among conifers that qualify
as obstructions.
I think it's an engineering judgement call. I'd base it on how much you expect the rooftop equipment to block smooth wind flows over the roof.
I'd call these fully exposed:
Link
Link
I'd start to call these partially exposed if I really needed to sharpen my pencil:
Link
Link
Ian Riley, PE, SE
Professional Engineer (ME, NH, VT, CT, MA, FL, CO) Structural Engineer (IL, HI)
If I really had to sharpen my pencil I would probably use the same criterion for the mechanical units as for the parapet: if they extend above the balanced snow depth, then the roof is not fully exposed. However, I don't usually work with snow loads large enough for Ce=0.9 to help appreciably.
