Feb 2, 2020 #1 2bad4um8 Mechanical Joined Feb 2, 2020 Messages 1 Location US What are the consequences of having a full port bypass going from a pumps outlet to it's inlet? Cavitation? Upstream flow? Bypass has a valve that is partially cracked. Process material is high visc and usually heated.
Feb 2, 2020 #2 Latexman Chemical Joined Sep 24, 2003 Messages 6,952 Location US Recycle from discharge to suction, less flow, less cavitation, less discharge pressure, higher temperature discharge (probably negligible). Good Luck, Latexman Upvote 0 Downvote
Feb 2, 2020 #3 EdStainless Materials Joined May 20, 2004 Messages 16,357 Location Waukesha WI USA Usually these lines go back a ways so that the recirculated product can be mixed in better. This help even our temperatures and minimize shear related issues. = = = = = = = = = = = = = = = = = = = = P.E. Metallurgy Upvote 0 Downvote
