22854
Chemical
- Sep 19, 2001
- 28
I'm interested to know opinions on which compressor type (alternative , centrifugal, ecc.) is mostly used or reccomended from different points of view (operational, maintenance, initial cost, ec.) nowadays.-
Service is to compress low pressure (0,5/0,6 bar g) gaseous CO2 coming from MEA or MDEA purification unit up to 160 bar abs. to feed into an urea reactor.
Temp: 40 deg. C
Normal flow: 15500 Kg/hr
Max flow: 21500 Kg/hr
Power: approx. 2800 kW
Temp: 40 deg. C
