mikeellsmore
- Feb 21, 2003
- 3
We use gravity flow to transfer leachate (contaminated water) from a tank to an open pond on different elevations. Head difference, between the level in the tank and the dischage pipe end into pond, is 4-6 metres. Horizontal distance bewteen the tank and the pond is about 1000 metres. Pipe diameter 63 mm poly. Pipe goes through a valley between the tank and the pond that is about 2 metres below the discharge point. System suffers from air locks each time we go to use. (Pipe is drained between uses as it forms part of another system). Bleeding the air from the low point restores the flow.
Can someone explain the fluid mechanics of why an air lock stops flow in this type of situation, what head difference would stop this occuring?
