kingnero
- Aug 15, 2009
- 1,750
I'm looking for the kind of steel (QT most likely, TRIP, CP or DP, ...) that this is. Should be an f[sub]y[/sub] (R[sub]p,0.2[/sub]) = 1100 MPa steel.
When I google for St1100, all I get is Honda motorcycles (the same type I got, amongst others...).
Does any of you have access to the Stahlschlüssel (key to steel) and can tell me the werkstoffnummer? With that, I can look further.
