dhanish.ab
Hello Everyone,
I have been tasked to bring the existing drawing into our current system. On doing so i am hurdled with issues in Tolerance.
Old drawing points in drawing title block about the dimension calls out for ISO STANDARD TOLERANCE GRADE 13. With all liner dimension. I assume all dimension should refer some reference.
Please note there is no other mention of tol. in tittle block apart from this
Currently we follow ISO 8015 standard, We define the position tol. and profile tol. and apply basic dimension and GD&T
Can any one guide on how do i go about it. I have found very little documents on ISO grade 13 and finding it hard to interpret the same.
I just want to make sure i callout the correct value when i draft to out current drawing standards.
Any suggestion will be of great help
