shacked
- Aug 6, 2007
- 176
I am designing a plywood beam, using APA's "Design & Fabrication of all plywood beams" supplement as a guide.
My question is concerned with the type of adhesive to specify. The only information it gives is that the adhesive shall conform to ASTM spec D2559.
This is pretty much no help whatsoever. I have looked at some typical adhesives and none comply with this testing specification.
Does anyone have any or know of a resource that I could use to determine which adhesive complies with this ASTM spec? Or any other information concerning the fabrication of plywood beams.
