1
- #1
mechengineer
- Apr 19, 2001
- 266
Why do you need MAWP?
A customer needs a pressure vessel to operate in an operating pressure & temperature. After the consideration of the design margin to get the design pressure & temperature to design the pressure vessel by a vessel manufacturer. It should be a very simple thing without MAWP. However, MAWP makes a design of pressure vessel became two designs, one is based on the design pressure and another is based on the MAWP.
I disagreed with the comment that MAWP is the way for optimal design of pressure vessel to save material. Design engineer will be unlikely to increase the thickness if the thickness is sufficient with the design pressure, no need using MAWP to prompt for the overdesign.
Disadvantages of MAWP in pressure vessel design
• If any thickness change of the pressure vessel components will affect the MAWP and further affect the pressure of the hydraulic test. The hydro-test pressure in GA may have to change in very revisions. If use design pressure, you would not be worry about the hydro-test change due to a thickness change caused by the material availability in work shop or any other reasons.
• PV Elite does not use MAWP, but use the design pressure to calculate the saddle support, the skirt support and nozzle external load analysis by WRC297 or WRC107. You have to use MAWP as a ’design pressure’ (set the design pressure =MWAP in PV Lite) to re-run the all programs.
• Double engineering work.
• Misleading and catering to customers' mentality of higher design pressure and more safety. ‘The MAWP to be calculated…, the MAWP shall not be limit by flanges ….’ is a typical in most of client specifications.
Solution:
Always makes a design pressure as MAWP in your design if possible.
I sincerely appeal to EPC engineers or users, according to the contract and data sheet, the manufacturer should only be responsible for the safety of the pressure vessel under design pressure. If the working pressure of the vessel has never been upgraded during the entire service life, such situation (pressure upgrading) is rare in practice, the MAWP design may be meaningless and waste engineering man-hours. You also spend engineering man-hours to review MAWP for nothing.
Solution:
