AnhsirkT
Chemical
- Aug 24, 2020
- 85
1. At the time of turbine trip why extraction valve closed immediately? if it is open what happen
2.At the time of turbine warm up(steam taken from extraction side to HP casing ) why balance line in turbine should be closed?
3.why lube oil pressure should be 2.5 bara while it return pressure is 1 bara?
4.if chest pressure(in b/w GV and TTV) goes higher what can be cause of it?
Do not think twice
Do not think twice
