dik
- Apr 13, 2001
- 25,839
I was trying to determine how you can subscripts to variable names in Bricscad. Just discovered if you enter in 'Text Override' the following:
\A1;text\H.66;\S^abc
The dimension value is 'text' and the subscript is 'abc' with the subscript text equal to 0.66 x text height.
I often use Bricscad to make pictures in SMath and for variables, I can now enter them in the CAD drawing that I import into SMath. Can't upload either image or file... site is broken.
Dik
Dik
