TJT
Mining
- Apr 11, 2002
- 19
I am currently using a doppler style meter to measure the flow of a zinc concentrate/water slurry to an autoclave. The slurry varies between 65% - 75% solids and the average flow is approx. 200 litres/min. We use Toyo style pumps so the flow does pulsate. The pressure is approx.200 psi, and the line size is 3". I am wondering if a different type of meter, mag for instance, would give us a more accurate measurement.
Thanks...Tim
Thanks...Tim
