h-badawy
- Jan 8, 2015
- 132
Dear experts,
In order to calculate(K) for design columns , i have to know first type of building (sway or non-sway) and as per the etabs manual design software takes k=1 as a default , and he gives an option to the user to change the value as per section 10.10.1 ACI318-08 , so shall i calculate sway and non-sway manual by calculating Q-index and put values of K for each columns ?
Thank you for help
Thank you
Thank you for help
Thank you
