Dusni
- Aug 7, 2016
- 12
The member is a steel box shape consisting of (4) plates held together with an angle in each corner. Each angle leg has a single bolt every 6" along the member length.
I calculated the shear on the angle bolts in the direction parallel to the span due to vertical shear using VQ/It.
For shear on the bolts due to torsion on the member I'm not as confident...here's my calc. Am I missing something?
Thanks!
![Torsion_s7yejk.jpg](https://res.cloudinary.com/engineering-com/image/upload/v1608412008/tips/Torsion_s7yejk.jpg)
Thanks!
