Connections for timber frame at roof eave
ngneer
30
I have a building that has an existing built-in gutter which is &quot;hung&quot; on the wall. We want to remove the gutter, install a new frame (looks like this < ) with the 2 members attached to boards along the wall. My question is: how should I connect member to member (bolted next to each other or top 2 by 6 resting directly on bottom 2 by 4) and member to board along wall. Thanks in advance.
