Theoretically anything is possible, but the member sizes required to make this work will be gargantuan, and the stiffness required at the top to resist the loads imparted at the top of the stair is high and therefore hard to get to work with standard framing.
You could look at having a cranked slab from that mid-height landing down to the floor, still need to find a way to support the stair at the top.
