can someone give me the prompting on which formula must be used to calculate the pressure drop through the non-standard angle bend. (assume) I know r/d ratio and angle as well.
"Crane" recommends to use the following formula, but it looks strange:
Kb=(n-1)x(0.25 x Pi x ft x r/d + 0.5K) + K
where n is the number of 90 deg bends, but for eg. 35 deg bend it makes 35/90=0.3889. So, I should substitute this value in place of "n" ???
thanks everyone in advance
