MegaStructures
Does anybody have experience specifying a CJP weld for HSS with a backer bar and can share some of the details of the design? The first thought for the backer is to bend plate to fit the inside of the HSS where a readily available HSS size is not available.
Yes, I do know that using CJP welds is not preferred and would be expensive. When connecting HSS branches in a space truss it's not possible to fillet weld all-around due to the obtuse angles of the HSS faces and for thin tubes a PJP weld is not possible.
“The most successful people in life are the ones who ask questions. They’re always learning. They’re always growing. They’re always pushing.” Robert Kiyosaki
