Ansys Beginner - Not FEA Beginner
rc0213
110
I was told that getting formal training was not available to me, at the moment. They believed I could learn how to use AnSys FEA on my own. I am thinking, "NOT!!!!!"
BUT, I'm giving it the old college try, anyways, to prove to them that it CANNOT be done on my own.
I have done simple FEA on SolidWorks, before their massive upgrade. I left the company before I could master it.
So, I understand the basics of FEA.
I have a degree in Industrial and Mechanical Engineering, so theory is not the problem.
The issue are the basics of how to start structural FEA, like beam analysis. I am analyzing forces applied to a mechanical assembly. I don't want to use the terms wrong, which I might have.
So, I will end this ask for help with this.... I am needing references I can use to start learning to use AnSys.
Thanks for any suggestions.
If you are so convinced that it CANNOT be learned on your own, why are you bothering us? Yes, you can learn it yourself, if you really want to. I just taught myself how to analyze an electromagnet to determine flux density and Maxwell forces with the old unmaintained and unsupported low frequency emag module in MAPDL, and I'm 70 years old and last looked at electromagnetics when I took a physics class back when Gauss was still in grad school. As far as a reference, get on YouTube and search on "ansys beam analysis". There are only about 30 or 40 videos.
Rick Fischer
Principal Engineer
Argonne National Laboratory
You can go there:
There's plenty of examples, where you can learn apdl syntax. They're usually at the end of each page. Example:
Then I suggest you to use Ansys HELP and learn most commands! You'll se that, when youv'e seen 60-70 different command (especially *get) you'll start to understand everything.
