Total max weight hung on single stud
phloaw
Student
Jun 19, 2021
Hi, I'd like to hang a gas central heating vertical radiator on a single timber stud behind a thin plasterboard wall, hence we are talking of a shear force.
The stud is 38mm wide (actual size) and (presumably) around 76mm deep.
The radiator would weigh around 35kg in total, spread across a number of screws which can vary between four and ten (I have some freedom with that).
Would that be ok? If yes, what screw size would you recommend?
Thank you.
This isn't a DIY/home improvement site, even the student section.
Anyway, you'll likely get more suitable and comprehensive advice on a DIY discussion board, like DIY Chatroom, or any of a dozen others.
