Mateus_R
- Mar 15, 2018
- 48
I'm not familiar with the standards that rules the design of equipment to be used in a ship/platform and I would like to know how to combine the accelerations (normal, longitudinal, transversal) when calculating a structure to be used on an offshore asset.
I imagine that from an hydrodynamic analysis we obtain the max. value of acceleration in the three directions and in a certain way we can combine them.
Selecting the max. values from the three accelerations and apply to the structure could be conservative (since most probably they do not appear at the same time) and so I imagine that we could combine the accelerations using a sort of load combination factor: for example 50% of the max. accelerations. This make sense? In this case, what is the good practice?
I'm not calculating any structure, I'm just curious about the approach.
Thank you for your help.
