Redacted
- Mar 12, 2016
- 160
Hi there, I have seen on quite a few different engineers and architects drawings where they call out for a 'wall stiffener' under lintels, which is essentially filled CMU block with 1T12 or 2T12 typically. See the screen shot of a note from a drawing below.
I am trying to understand the purpose of the rebar in this case. They do not ever show or call out footings to go with the filled CMU wall, so I am assuming that the CMU wall and rebar would essentially just be sitting on the floor slab. They can perhaps drill about 6" or so into the floor slab to place the rebar but this most likely won't be enough to develop it for any moments? I'm not sure where moments would be coming from either as I would assume that for lintels there would just be the vertical load.
So I guess my question is what would the purpose of the rebar be if it does not get fully developed into a footing to take moments? Should they be calling out for a footing even though the lintels are lightly loaded?
The local building code does call for CMU block to be fully grouted under lintels over 6' but doesn't mention anything about needing rebar?
