swiedmann
- May 8, 2002
- 2
Were in the process of designing an optical instrument housing, and are considering a high-precision bearing (ABEC 5) for a rotating fixture.
The bearing has minimal clearance (0.0002". The torque on the bearing is extremely low, around 3-5 ounce-inches (assuming no pre-load via interference fit).
Since it is lab equipment, we would like to use a dry lube, and were thinking of Sprayon T.F.E.
Does anyone have a better recommendation, or is a light instrument oil required for this application?
Thanks for your help.
